tianfd 发表于 2015-12-8 15:56
在实际网络中,从2/3G切换到4G的Attach流程中,可以看见AttachRequest消息会携带GUTI Type为MAP GUTI,指 ...
The additional GUTI in the Attach Request message allows the new MME to find anyalready existing UE context stored in the new MME when the old GUTI indicates aGUTI mapped from a P-TMSI and RAI.
在附着请求消息中:
If the UE holds avalid GUTI and the old GUTI indicates a GUTI mapped from a P-TMSI and RAI, thenthe UE indicates the GUTI as additional GUTI.
还有一句:
The new MME verifies whether it holds subscriptiondata for the UE identified by the GUTI, the additional GUTI or by the IMSIreceived with the context data from the old CN node.
也就是新MME根据GUTI、add GUTI或IMSI来判断,向哪个old 核心网节点(MME还是SGSN)去要UE的上下文。
tianfd 发表于 2015-12-10 15:41
“The new MME verifies whether it holds subscriptiondata for the UE identified by the GUTI, the ad ...
add guti这个东东在普通的附着流程中没有作用。主要是用在ISR(idle mode signaling
reduction:空闲模式信令缩减)场景下的。就是为了防止用户频发在2/3G和4G边界穿越带来大量的TAU/RAU更新所所的一个优化措施。主要作用是:
“The additional GUTI in the Attach Request message allows the new MME to find any already existing UE context stored in the new MME when the old GUTI
indicates a value mapped from a P-TMSI and RAI.”
从《3GPP系统架构演进原理与设计》一书介绍ISR章节中这样写道:“UE从E-UTRAN接入,在TAU请求中包含的Old GUTI为P-TMSI和RAI映射得到,可从正确的SGSN获得UE上下文;而附加GUTI为以前SGSN/MME结合节点曾经分配给UE的GUTI,用于确定结合节点的MME部分所保存的UE上下文可被正确找到并替换为最新的UE上下文内容。”
