查看: 5193|回复: 6
问:关于APN重定向(即APN纠错) [复制链接]
Rank: 8
义 超级之星 勤 论坛核心会员
发表于 2012-3-14 13:43:57 |只看该作者 |正序浏览
在alex中关于APN重定向有一段描述:
“For a single subscribed APN  or when there are multiple subscribed APN s with the same PDP  type or combination of  PDP  type and PDP address as the requested APN , configuration of the SGSN_ApnRedirectToSubscribedApn node property is required to enable redirection to this single subscribed  APN .”
对于“ single subscribed  APN ”比较好理解,直接重定向到该签约APN。
但是对于“when there are multiple subscribed  APN s with the same  PDP  type or combination of  PDP  type and  PDP  address as the requested  APN ”这句不好理解,“当签约有多个PDP类型或PDP类型与PDP地址混合 与请求APN相同时”?这个时候怎么重定向到“ single subscribed APN ”呢?
谢谢
欢迎多多交流
PS CORE & SS7 & SIGTRAN & IP
有相关的专业技术网站/Q群也多谢推荐
7#
发表于 2012-4-11 22:46:01 |只看该作者
hycl5410 发表于 2012-4-11 13:14
另外提一句
For multiple subscribed APNs with the same PDP type or the same PDP type and PDP address ...
“如果签约a,b,c, SGSN default d,请求e,在开redirect功能以及配置正确的情况下,选哪一个?随机还是固定为第一个签约(a)?”
我看到的资料是:E厂家的SGSN某老版本下会拒绝PDP激活,并且回CC33。但不确定现在的新版本的行为。
Rank: 8
VIP 论坛核心会员 特殊贡献奖
6#
发表于 2012-4-11 13:14:08 |只看该作者
另外提一句
For multiple subscribed APNs with the same PDP type or the same PDP type and PDP address with the requested APN, the SGSN_ApnRedirectForMultipleApn node property can be configured to have the incorrect requested APN substituted by the SGSN default APN (when the SGSN default APN is included in the subscribed APN) or one of the subscribed APN that is not a wildcard. Configure the SGSN_ApnRedirectForMultipleApn node property, by using the set_nodeprop CLI command.
Rank: 8
VIP 论坛核心会员 特殊贡献奖
发表于 2012-4-11 13:11:22 |只看该作者
这里写的倒是比较清楚
Supplementary Configuration
For activating the feature, the following supplementary configuration is required:
For configuring the SGSN default APN, that is, the Gn_DefaultAPNGSMNetwork and Gn_DefaultAPNUMTSNetwork node properties, use the set_nodeprop CLI command.
For a single subscribed APN with the same PDP type or the same PDP type and PDP address with the requested APN, the SGSN_ApnRedirectToSubscribedApn node property can be configured to have the incorrect requested APN substituted by the single subscribed APN. Configure the SGSN_ApnRedirectToSubscribedApn node property, by using the set_nodeprop CLI command.
Rank: 8
义 超级之星 勤 论坛核心会员
发表于 2012-3-14 22:42:43 |只看该作者
回复 yonka 的帖子
断句我可以试着断一下
不知道这样断句方便看不?
我也不晓得为什么先是单个,再又提到多个,然后又重定向到单个~~~- -!
欢迎多多交流
有相关的专业技术网站/Q群也多谢推荐
Rank: 8
义 超级之星 勤 论坛核心会员
发表于 2012-3-14 22:39:49 |只看该作者
这个~
我也没懂~
alex有时长句写的太恐怖了~~
我再了解一下~不好意思
欢迎多多交流
有相关的专业技术网站/Q群也多谢推荐
发表于 2012-3-14 22:26:34 |只看该作者
不好意思。没看懂。主要是不知道怎么断句。前面说只签约一个APN,后面又说签约多个APN。然后又说要重定向到这个唯一签约的APN。。。
GMT+8, 2024-5-21 01:36 , Processed in 0.060422 second(s), 17 queries .
