查看: 4447|回复: 0
求助:关于高频次PDP建立用户引起的PDP激活成功率低的案例 [复制链接]
发表于 2011-11-22 14:46:51 |显示全部楼层
我觉得这种高频次应该是终端的不正常现象。因为关于PDP激活失败的场景说明,在TS24008的6.1.3.1.3中有明确说明:
“Upon receipt of an ACTIVATE PDP CONTEXT REJECT message, the MS shall stop timer T3380 and enter/remain in state PDP-INACTIVE.
6.1.3.1.5        Abnormal cases
The following abnormal cases can be identified:
a)        Expiry of timers
        In the mobile station:
        On the first expiry of the timer T3380, the MS shall resend the ACTIVATE PDP CONTEXT REQUEST and shall reset and restart timer T3380. This retransmission is repeated four times, i.e. on the fifth expiry of timer T3380, the MS shall release all resources possibly allocated for this invocation and shall abort the procedure; no automatic PDP context activation re-attempt shall be performed. ”
   也就是说MS收到PDP激活拒绝消息后,最后重试4次,然后就不能自动去执行PDP激活的重新尝试。这是一个正常行为。后面的你说可能导致RNC资源占用过高倒是很有可能的,个人感觉。
   之前有篇帖子讨论过认证,是在cause code大全版块。公共APN例如cmnet一般都是透明接入,不用认证,回CC29可能是因为欠费。而企业APN是非透明接入,一定要认证的。在MS发出的PDP激活请求中,有个PCO的IE,里面写道了PAP用户名和密码或者是CHAP认证。
GMT+8, 2024-5-13 18:24 , Processed in 0.019224 second(s), 9 queries .
