- 在线时间
- 329 小时
- 最后登录
- 2015-9-9
- 威望
- 116
- 金钱
- 23093
- 贡献
- 67
- 注册时间
- 2012-2-23
- 阅读权限
- 150
- 主题
- 8
- 帖子
- 491
- 分享
- 0
- 精华
- 0
- 积分
- 23883
- 相册
- 0
场景楼主说的很清楚了。我把规范抄一段给大家看看:
3GPP 24.008
4.7.4.2.2 Network initiated GPRS detach procedure completion by the MS
If the detach type IE indicates "re-attach not required", then, depending on the received cause code, the MS shall act as follows:
# 7 (GPRS services not allowed);
The MS shall set the GPRS update status to GU3 ROAMING NOT ALLOWED (and shall store it according to subclause 4.1.3.2) and shall delete any P-TMSI, P-TMSI signature, RAI and GPRS ciphering key sequence number. The SIM/USIM shall be considered as invalid for GPRS services until switching off or the SIM/USIM is removed. The new state is GMM-DEREGISTERED.
A GPRS MS operating in MS operation mode A or B in network operation mode I shall set the timer T3212 to its initial value and restart it, if it is not already running.
A GPRS MS operating in MS operation mode A or B in network operation mode I, is still IMSI attached for CS services in the network.
个人理解,MS充值之后再点任何数据连接都不会有操作(ATTACH,PDP都不会)。因为GPRS已经彻底被它自己给disable了,直到重启或者重新插卡。
