查看: 8006|回复: 0
SGSN与BSC的PFC协商流程,是否存在一个参数控制这个流程 [复制链接]
发表于 2012-7-13 21:31:02 |显示全部楼层
重试次数和等待时间都有的。有关于等待对方报文的等待时间,BSS侧是T6计时器(发送DOWNLOAD-BSS-PFC PDU 启动 ,收到CREATE-BSS-PFC PDU后停止),SGSN侧是T7计时器(发送CREATE-BSS-PFC-ACK PDU启动,收到CREATE-BSS-PFC-NACK PDU停止)。
SGSN的重试次数是:“If a CREATE-BSS-PFC-ACK or CREATE-BSS-PFC-NACK PDU is not received in response to a CREATE-BSS-PFC PDU within T7 seconds, then the CREATE-BSS-PFC PDU shall be repeated a maximum of CREATE-BSS-PFC-RETRIES attempts. After CREATE-BSS-PFC-RETRIES+1 attempts the procedure is stopped and the O&M is informed.”
也就是SGSN上有一个叫做CREATE-BSS-PFC-RETRIES的重传次数定义的。
BSS上也有一个,如下“If a CREATE-BSS-PFC PDU is not received for a DOWNLOAD-BSS-PFC PDU within T6 seconds, then the DOWNLOAD-BSS-PFC PDU shall be repeated a maximum of DOWNLOAD-BSS-PFC-RETRIES attempts. After DOWNLOAD-BSS-PFC-RETRIES + 1 attempts the procedure is stopped and the O&M system is informed. If a BSS PFC is not received then the BSS shall handle uplink and downlink transfers according to a best-effort default aggregate BSS QoS profile.”
叫做DOWNLOAD-BSS-PFC-RETRIES计时器。
但这里的问题是SGSN为什么要重发BSS-PFC PDU?因为上面的计时器是指收不到BSS的BSS-PFC-ACK PDU来重发的,本例是已经收到了,所以最好有抓包看看,是不是协商有什么问题。
GMT+8, 2024-5-16 10:08 , Processed in 0.033055 second(s), 9 queries .
