查看: 3870|回复: 0
RNC-SGSN的信令面和媒体面若干疑问 [复制链接]
Rank: 3Rank: 3Rank: 3
发表于 2012-10-22 00:27:42 |只看该作者 |正序浏览
1、SGSN创建信令面地址
    gsh create_ip_service_address -sn Iu-SS7-1 -ip x.x.x.5
   gsh create_ip_service_address -sn Iu-SS7-1 -ip x.x.x.6
   gsh create_ip_service_address -sn Iu-SS7-2 -ip x.x.x.7
  gsh create_ip_service_address -sn Iu-SS7-2 -ip x.x.x.8
  gsh create_sctp_end_point -no 3 -portno 2905 -nolis 17 -nolos 17 -dscp 40 -pn SctpProfile_1 -secsn Iu-SS7-2 -primsn Iu-SS7-1
   gsh create_sctp_end_point -no 4 -portno 2905 -nolis 17 -nolos 17 -dscp 40 -pn SctpProfile_1 -secsn Iu-SS7-1 -primsn Iu-SS7-2
  SGSN为每个RNC创建四个信令面地址,分成两个SCTP多归属 3和4,Iu-SS7-1中的两个地址9和10,分别在两个SCTP终结点中是主还是备,怎么确定,是否由RNC侧配置决定的??
RNC与SGSN信令面主要参数表:
link
RNC信令面地址
RNC侧偶联端口
RNC侧偶联端口
RNC侧偶联端口
RNC媒体面地址
SGSN偶联端口
SGSNA信令面地址
SGSNB信令面地址
1
x.x.x.33(primary)
28010
x.x.x.33
x.x.x.34
x.x.x.35
x.x.x.36
2905
x.x.x.1(Primary)
x.x.x.5(Primary)
x.x.x.37(secondary)
x.x.x.4(Secondary)
x.x.x.8(Secondary)
2
x.x.x.33(primary)
28011
2905
x.x.x.1(Primary)
x.x.x.5(Primary)
x.x.x.37(secondary)
x.x.x.4(Secondary)
x.x.x.8(Secondary)
3
x.x.x.37(primary)
28012
2905
x.x.x.3(Primary)
x.x.x.7(Primary)
x.x.x.33(secondary)
x.x.x.2(Secondary)
x.x.x.6(Secondary)
4
x.x.x.37(primary)
28013
2905
x.x.x.3(Primary)
x.x.x.7(Primary)
x.x.x.33(secondary)
x.x.x.2(Secondary)
x.x.x.6(Secondary)
查看偶联地址:RNC-SGSNB信令面的地址
Primary IP Path: x.x.x.7 - x.x.x.33          对于SCTP端口号为2905的link,按照表中规划,应该为RNC主地址-SGSN侧主地址,才是想要的结果,这里为啥出现这个情况??
Last used IP Path: x.x.x.7 - x.x.x.33        7作为主地址
Last used IP Path Time: 23:59:49.971 (2012-08-22)
Local Port:  2905
Remote Port: 28012
NumberOfLocalIPAddresses: 2
Local IP Address: x.x.x.7 (IPv4)
Local IP Address: x.x.x.6 (IPv4)
NumberOfRemoteIPAddresses: 2
Remote IP Address: x.x.x.37 (IPv4)
Remote IP Address: x.x.x.33 (IPv4)
Number Of IP paths: 4
IP path: x.x.x.7 - x.x.x.37
   PathStatus: ACTIVE
   PathT3cntr: 0
   PathMaxRTX: 4
   SRTT: 14
   Last RTO time: -
   HB status: Active
IP path: x.x.x.7 - x.x.x.33
   PathStatus: ACTIVE
   PathT3cntr: 0
   PathMaxRTX: 4
   SRTT: 50
   Last RTO time: 23:59:49.971 (2012-08-22)
   HB status: Active
IP path: x.x.x.6 - x.x.x.37
   PathStatus: ACTIVE
   PathT3cntr: 0
   PathMaxRTX: 4
   SRTT: 14
   Last RTO time: -
   HB status: Active
IP path: x.x.x.6 - x.x.x.33
   PathStatus: ACTIVE
   PathT3cntr: 0
   PathMaxRTX: 4
   SRTT: 14
   Last RTO time: -
   HB status: Active
这里为什么要建立四条SCTP链路,四条链路关系什么,每条链路的RNC两个信令面地址和端口号,对应的SGSN侧的两个信令面地址形成的4条path,之间什么关系??
SGSN配置中,在创建SGSN信令面地址的时候,没有明确5和7是主地址,而查看得到结果,5和7是作为主地址,7作为主地址,是否是由RNC侧数据配置决定的???
SGSN与RNC信令面互通是怎么操作的,SGSN收到RNC的数据,想要响应给RNC,是否是SGSN添加目的ip地址为RNC的信令IP,然后通过SGSN上的信令面的路由转发给CE,再转发到RNC侧,SGSN上有关OSPF的配置没有看懂。
诺西华为的SCTP端口,RNC侧和SGSN侧端口一致,比如RNC的28010---SGSN侧的28010,然而爱立信的SGSN侧的端口全部采用2905,为什么??
2、媒体面数据配置
      一个SGSN一个媒体面地址,gsh create_ip_network_subnet -nw Iu -ip x.x.x.3 -mask 255.255.255.255 ,然而在SGSN侧没有配置RNC的媒体面地址,RNC与SGSN侧的媒体面是如何互通的??
3、GN口的信令面和媒体面互通
    一个SGSN:一个GTP-C地址,一个GTP-U地址,还有一个DNS\NTP地址
   一个GGSN:四个GTP-C地址,八个GTP-U地址
   我凌乱了,信令面和媒体面是怎么互通的啊??GN口在做GTP封装时,怎么选择这些地址??另外,根据APN解析出的GGSN地址,是对应的GGSN什么地址??
   希望各位能帮助我解决下我的疑问,不胜感激,互相进步!
点评
admin  GGSN上将选择一块GTP业务板卡作为leader,用于监控所有的GTP业务板卡的状态和负荷并派发GTP处理业务。APN解析出来的地址就是GGSN侧这块GTP leader业务板卡对应的GTP-C地址。  发表于 2012-10-23 00:04:56
admin  我先回答最后一个问题。GGSN上的多个GTP-C和GTP-U IP地址是和硬件板卡相关联的。每个GTP-C和GTP-U业务板卡一个IP地址。但SGSN的GTP-C和GTP-U业务地址是多板卡共用的,所以就只要分1个IP。  发表于 2012-10-23 00:03:13
GMT+8, 2024-5-19 03:31 , Processed in 0.029362 second(s), 13 queries .
